Product
ESP32 Dagor Controller 2.4-alpha
The Dagor Controller is a fully integrated tiny solution for brushless-based actuators with wireless capabilities.
ESP32 based brushless motor controller for robotics applications. The Dagor Brushless controller has an on-board magnetic encoder, a three-phase MOSFET driver, three MOSFET half-bridges, a temperature sensor and current sensing resistors.
This board is fully compatible with the SimpleFOClibrary
Specification Rating
Dimensions 44 x 44mm
Power source voltage 5-24V
Peak current up to 40A
Magnetic sensor resolution 14 bits
Temperature sensor range -10 ~ 120°C
Mass 12 g
Microcontroller 240MHz 32-bit ESP32
€ 39.00
Order
Powered by
Features
  • Control modes
    Position, velocity and voltage.
  • Magnetic Sensor integrated
    14-bit sensor for absolute position feedback
  • Temperature Sensor
    Monitor the board’s temperature + Thermal shutdown
  • ESP32 Wireless capability
    Bluetooth and WIFI
  • Communication protocols
    ESP-NOW (wireless), UART
  • Available GPIOs
    Connect an external sensor/ encoder, control a cooling fan, Hall effect sensors
  • Indicator LEDs
    RED -> Faulty operation, Blue -> Battery connected, Yellow -> GPIO controlled
  • Power source voltage monitor
    Measuring the power supply voltage in real-time
  • BEWARE: Maximum continuous current depends on cooling
    The Maximum continuous current of the ESP32 Dagor Controller depends on the quality of heat-sinking and cooling. A small heat-sink or a cooling fan can have great impacts on the maximum continuous current the board can handle. The on-board temperature sensor is a great way to assure you don’t exceed the maximum operating temperature. Ask the community about it!
  • Shipping notice
    Dagor boards will be shipped by their creator David Gonzalez (@byDagor), from Mexico
Project examples
Ball and wheel control system
Github
This is a project of designing and controlling the ball and wheel balance system based entirely on the Arduino SimpleFOClibrary and the Dagor Controller.
Five Bar Parallel Robot - Big J
Hackaday.io
Big J is a five bar parallel robot that uses direct drive brushless motors as actuators working with the Dagor Controller board.
Haptic Brushless Control - Telepresence Demo - Steer by wire(less)
Very cool example project showing off the Wireless capability of the ESP32 board and creating a virtual link in between two motor positions.
Documentation
Dagor controller is a board created by David Gonzalez. It is a great open-source platform which is 100% compatible with SimpleFOClibrary. Here you can find links to the documentation, David's YouTube channel and Dagor's Hackaday project link.
