Product
SimpleFOCShield V3.2
The 3rd generation of the Arduino SimpleFOCShiled:
A low-cost, modular and user-friendly alternative for running gimbal BLDC motors with FOC algorithm.
Motivation
Gimbal BLDC motors can be used as a high quality replacement for the regular hobby motors, such as DC servos and stepper motors. FOC-controlled gimbal motors enable high precision positioning, very smooth (and quiet :) ) operation and highly responsive and dynamical behaviour.
However starting with FOC and BLDCs is not always easy and the aim of this board, belonging to the SimpleFOCShield family is to provide an easy and user-friendly way of using these motors in your projects. While at the same time, being modular and highly configurable, enabling more advanced application scenarios as well.
Main Goals
  • To enable true FOC control for controlling gimbal motors (up to 100W)
  • To be as simple to use and as plug-and-play as possible (in combination with the SimpleFOClibrary)
  • To be as modular and configurable as possible
  • To be completely open-source (software/hardware/fabrication/..)
  • As simple to manufacture as possible (especially for the community)
€ 23.00
Order
Powered by
Features
  • Plug & play
    Using SimpleFOClibrary and any gimbal motor.
  • Stackable
    Stackable 2 shields (2 BLDC motors + 2 position sensors)
  • Configurable pinout
    Customise the pins used by the board.
  • Encoder Pull-Ups
    Integrated configurable 3KOhm Encoder pull-ups
  • 8V Voltage regulator
    Integrated configurable 5V voltage regulator L78M08
  • I2C communication Pull-Ups
    Integrated configurable 4.7KOhm SDA/SCL pull-ups
  • Open-Source
    Schematics and fabrication files fully available on github.
  • Arduino Headers
    Compatible for stacking: Arduino UNO/Mega, Arduino DUE, stm32 Nucleo, ...
  • Max Power 100W
    Max current 3A (3.5 Amp peak), Power supply 8-35V.
  • Current sensing
    Two phase in-line current sensing - up to 5A bidirectional
  • BEWARE 📢 : SimpleFOCShield is designed for gimbal motors
    SimpleFOCShield has been designed for gimbals motors with internal resistance around 10 Ohms. Using this board with high-power drone motors may burn the L6234 chip integrated on the board. The chip can handle up to 5Amps of current for short periods of time, but in for long-term operation (without the heat-sink) the current should stay under 2 Amps.
    - It is possible to use this board with low resistance motors but it requires a bit of experience and it is not recommended for beginners. Ask community about it!
  • BEWARE 📢 : Field Oriented Control processing requirements
    The true field oriented control with current sensing requires considerably higher processing capabilities than sinusoidal commutation approach (foc without current). Typically the required current control frequency is in the range of 10kHz. Therefore in order to have a great current control performance using this board we suggest to use stm32 boards such as Nucleo-64 boards,esp32 based boards, Arduino DUE, Teesny boards and similar higher performance microcontrollers. This board will work with Arduino UNO as well but the performance of current sensing may not be good enough for some applications.
    - But it is important to note that all the functionalities of the SimpleFOCShield v1 are included in this board as well and you will still be able to control any Gimbal motor to the very high degree even with the Arduino UNO and similar atmega328 based chips, but the real-time current control might be limited.
What can I do with this board?
Possible applications range all the way from simply substituting a servo motor in your project, over the high precision motion control of camera gimbals all the way to the highly dynamical applications such as robotics.
This board can also be a cool platform for student projects, to make experiments such as ball and plate, inverted pendulums, segways, inertia wheels and similar. These setups are usually very expensive and hard to calibrate and design.
Project examples
Reaction Wheel Inverted Pendulum
This is a project of designing and controlling the reaction wheel inverted pendulum based entirely on Arduino SimpleFOClibrary and SimpleFOCShield .
  • Arduino UNO using SimpleFOClibrary and SimpleFOCShield
  • All CAD designs available for modification and STL files provided
  • State-space LQR controller
  • Very simple to assemble, configure and setup.
Haptic control example
Project link
This video demonstrates SimpleFOClibrary support for Arduino SimpleFOCShield and using multiple motors with Arduino UNO. The project examples are based on bidirectional haptic control.
Documentation
The aim of the SimpleFOClibrary and SimpleFOCShiled is to demystify the FOC algorithm and to provide the community a simple way to use this powerful algorithm in their projects. Therefore this board is completely open source and fully documented. If you are interested in manufacturing this board on your own, make sure to check the board fabrication documentation section. Don't hesitate to contact me if you have any suggestions or need any more details about the board!,
